Thanks nick
Sounds similar.what speeds can you Get yours to do it? Mine does it from walking pace up to about 35mph.
I changed to ebc red recently and I think it slightly worse,not more violent worse,but will do it before it warms up now.
How did your stub axle splines look? Mine were quite worn. Didn't measure free play but guess 1mm at half shaft stud mount.
Mine is slightly different in that I can push through it. If I push harder on the pedal it stops shudder(more of a groan)
Do you mean if you pull on handbrake the shudder stops?
Not sure what to do next, but will visit brake specialist shop soon.
