Stewart-Warner 240- A -- C --D I.D. and NOS Parts
Good afternoon. To all resident Cobra experts, I only respond with fully documented information. According to the Design for Performance with Stewart-Warner Instrumentation, 1973 addition, page 29, --- S-W heavy duty Electric Fuel Pump, Electric fuel pump specifications: gas line connections: 1/4" internal P.T. --- Model 240-A (12V) pos. or neg. grd ---- -- 240-C (24V) pos. or neg. grd. Factory pressure setting : 3 1/2 - 4 PSI, adjustible 1-8 PSI (at the pump). Model 240-D (12V) Same specifications as Model 240-A less automatic pressure regulation. Preset pressure 5 1/2 PSI . If anyone needs more information, I can supply the part numbers for the 12 Volt coil kit and the switch kit for the pumps, so you can find them yourselves. I can also supply both expensive, unobtainium, kits, NOS in original S-W red and orange boxes for the lucky guys who bought 240-C pumps on ebay without doing the necessary research, and would attempt to change them out themselves, rather than having them done professionally, and tested here by our, 601HP, David. Thank you
