  #27 (permalink)
Old 03-22-2015, 11:07 AM
Default What color is the oil ???
Texas DOC Tom what color is the oil in the bell housing?? Brown or Red. I believe that T series trannies all take ATF fluid which is red. If the fluid is brown, It could be burnt ATF,or motor oil . I look at a 3 second video and the oil looks brown, yes, no ???? Is the oil thick like motor oil of thin like ATF? Rick L.
Ps I have seen motors leak oil from the front of the motor to the back along the oil pan. and without the dye you would have figured that the rear main was the problem. Same applies for the plugs in the back of th motor block for the oil passages. No sealer and some plugs leak. Spray is everywhere but on the flywheel and clutch. There is a lot of air blowing around inside that bellhousing. Enough to suck in HTOBearing lines and rub them through on the pressure plate.
