03-23-2015, 12:52 PM
Cobra Make, Engine: SPF#0760
The insert in the center of the steering wheel (plastic cap-like cover) pops right off the steering wheel. Held on with O-rings on center cap going thru opening in steering wheel.Very important to use a lever device that is softer than the material on the steering wheel spokes or you will scratch or gouge the metal. Very easy to damage. Plastic lever, maybe plastic spoon, etc. Some people who had ill fitting center caps used a dab of silicone to keep it in place. Use dental floss to cut thru the silicone in present. Floss may also remove center cap if it's not jammed on the wheel. I have photos of back side of cap if you need them for reference.
SPFWiringDiagrams@Comcast.net
