Thread: FE sparkplugs
Old 03-26-2015, 09:35 AM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Heat range actually can make a big difference for street driven cars on pump gas.
For modern heads with 14mm plugs, I usually use an Autolite AR3924. For the 18mm variety, the Autolite 45's give me good results.
Thanks very much. A follow up if I may, since I've considered that plug . In a 500HP 406 with Edlebrock Performer heads 10.5 compression, where would you gap them?
The older I get, the faster I was.
