Old 03-29-2015, 07:59 AM
patrickt patrickt is offline
Originally Posted by joyridin' View Post
Just out of curiosity, what type of gear oil are you using? Is it synthetic or regular?
It has to be "just right" for your set up (meaning, not the gear ratios, but the configuration of the rear itself). My rear works best with Moroso Climbing Gear lube with two tubes of the GM LSD additive. Not getting the combination just right results in ratcheting around corners.
