I'd say compression test, a leak down test to isolate the offending cylinder/s.
Then engine out.
Does the honing crosshatch RA suit the rings you have used?
I prefer to have the crankcase breath from the valley or the crankcase via a baffle plate which allows the heads to drain more easily. High blow-by makes it difficult for the heads to drain back.
Gary
