Originally Posted by Wisconsin_Snake
From a previous thread I had posted, it was recommended that I put a stop behind the gas pedal to prevent putting strain on the throttle cable when reaching WOT.
When looking at building out a stop, I realized that the amount of open space between the gas pedal (actually all the pedals (brake and clutch)) is like ~6 inches or more.
Is this normal?
It seems that the pedal when depressed should be allot closer to the firewall.
I replaced my throttle cable this winter, before cutting the cable to size it is important to hold pedal to floor. Try adjusting your ferrel at the Carburator or linkage. If not enough adjustment, I would buy a new cable and cut to correct length (allowing for pedal to hit floor). My pedal has no stop but the cable and linkage is adjusted so pedal is at the floor on WOT. Hope this helped?
