Old 04-11-2015, 02:27 PM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
Do you have room to run piece of hose over stud, if you do you could use tight fitting hose and cut grommet in half and glue grommet to hose, then slide hose over bolt or stud until the half grommet touches body. Use the half grommet with piece of hose for the other side.
