  #31 (permalink)
Old 04-11-2015, 08:53 PM
1ntCobra's Avatar
1ntCobra 1ntCobra is offline
Abnormal CC Member
Today I tried inflating the tires. I had my doubts since the outer rubber layer was split on some of the tires. The back tires filled easily, but the front tires were not cooperating. I tried jacking up the fronts so that the tire bead could get back on the rims and that worked.
I filled the back tires to 25 psi and the fronts to 30 psi.
The ratchet for the jack in the trunk did not work, but luckily I found a big adjustable wrench nearby.
The oil on the dipstick looked clear. I guess the oil must have just been changed right before the car was parked. The transmission fluid looks good too. However it looks like the coolant will need to be topped off.
