Old 04-14-2015, 02:57 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
You need a switch that operates (closes contact) when clutch pedal is close to floor, unlike a brake pedal function which operates after small pedal travel.
So you need to look at the top of the pedal near the fulcrum to determine which part of the pedal you could mount the switch nearby to, to perform the function as desired.
Gary
