Old 04-16-2015, 07:36 PM
Roger Bolick Roger Bolick is offline
Cobra Make, Engine: Exact427
TEXAS winning Electric Radiator Fan formula...
(SPAL High Performance 16” with sealed motor)
Aluminum core, 2 rows of 1 1/4" tube.
Core is approximately 350 sq in.
Spal Radiator Fan Parts:
1. 30102120 - 16" puller fan, straight blade, quantity 1 (flat sides 15.63", 16.22" OD)
2. 30130074 - 16" fan gasket, quantity 1
3. 30130017 - Plastic fan bracket, quantity 4.
4. FR-PT - Jumper Harness (or AMP connector Code 180908)
5. 30 Amp Relay / Fuse
Spal makes a "pusher" fan, but the straight blades work either way.
I purchase the Puller and just reverse the incoming connector pins for front mount.
ONLY runs:
1. while idling AFTER a high speed run (stop sign after interstate off ramp)
2. extended idling (more than 2 minutes)
3. 15 mph bumper-to-bumper traffic.
