Chris,
What bellhousing? and what flywheel?
The throwout bearing has a "stroke" of 10.5mm as per Holden SI.
So if the bearing is back 10mm from it's unloaded position, technically it should work.
Can you move the pressure plate fingers?
What is the clamping force? How does Centreforce rate the pedal feel?
Gary
