Old 04-30-2015, 04:51 PM
jluebben jluebben is offline
Cobra Make, Engine: CMC Ford big block
Default Rear spring geometry
I purchased a CMC frame and body and just started installing a 1990 8.8 rearend. The spring mount on the lower control arm is 1 5/8 inch behind the upper spring mount on the frame. So the spring sits on an angle and does not look correct. I will try to add a picture. Is this misalignment O.K. or do I need to cut the upper spring mount off and re weld it back further? The rear end did bolt right up and is centered in the frame. Thanks for the help!!!!!
