Thread: trailer build
Old 04-30-2015, 10:50 PM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
What sort of springs are you planning to use? PhilM had a very nice trailer using rubber torsion bar axles. I liked them because they allowed the trailer deck to be set very low and looked very straight forward to mount.
ive seen those ones used but ive been told when dirt and grit gets in there it chews the rubber out and they flog out they are pretty expensive as well
your right tho you can build them low tho .
my last trailer i used 4 inch drop axles and that got the deck to about 350 mm off the road this time i will be using 2 inch drop as the 4 inch are nearly double the cost . i will be using a rocker spring set up rated at 3,5 ton with electric brake on all wheels and a break away system for just in case it all turns to poo and the trailer departs from the car .
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
