Old 04-24-2002, 06:44 AM
Double Venom's Avatar
Double Venom Double Venom is offline
uhhh, "D"
Ed's right. Do NOT screw anything into the radiator. Tell me the model of the fan you are using.
If you have a fan with two large 90 degree metal brackets, you will have to come up with two "legs" that you can mount 90 degrees to and on the frame, then mount the brackets to these.
You want to keep the fan as tight as possible to the radiator.
You can go to Jegs, or Summitt and purchase an install kit: I'm not wild over them, but they do work. Cost is abut $9.00, includes 4 plastic straps, which sort of resembles wire ties, with a button head. You simply push these through the radiator, very carefully, then through the mounting holes of the fan shroud, then push on the supplied "buttons". Two things, make sure they are as tight as possible, and make sure you have it where you want it the first time. These are one way only! (Note: these have been known to move around after time, and with the weight of the fan on them, have actually damaged the radiators.)
Hope this helps.
DV
300 Cobras is NOT enough, and by golly we are going to make it!
