Old 05-01-2015, 09:54 AM
Double Venom's Avatar
Double Venom Double Venom is offline
I hope your still happy with our work! For what it's worth you are the oldest
(Business wise) that I've been in contact with! Now if I could hook up with the late 70's! ��
GROUNDS: A single ground to the frame is NOT a proper ground! Battery ground to the motor/bell housing FIRST. Then using a flexible ground strap from the engine /motor mount to the frame. Your grounding problems are over! (This critical for EFI engines or any engine using electrical accessories! I.E. MSD's etc.
