Originally Posted by Chachi427
I had the same issue and it was my magnetic pick up. Check the continuity across the pick up when warm and cold. If it reads greater than 1K ohms then I would first replace that. Only about a $40 fix.
the pick-up will read differently (more resistance) when hot. but the critical reading is less than !,000 ohms I believe. Check with MSD on that. Also. it does help to have the box in a "breezy" area if located under the hood. I like to put them under the dash when possible.
Z
