Turn signal arm set screw
Turn signal arm issue. Today noticed turn signal arm was loose and flopped around some. Everything works fine just the arm is very loose. I tightened the set screw a little and the arm would then not move at all? Backed the screw in and out and the arm is either too loose or too tight and won't move. Is there a sweet spot the lever needs to be in when tightening the set screw? I tried various arm positions but no difference.
What is the solution here?
Thanks
RT3_1350
