dcapo, Here is how I install them. I'm assuming you have the 16"Spal fan from Classic. On the top and bottom of the radiator there is a small aluminum channel, I run all four straps to this channel, drill 4 small holes to accept a stainless 10-32 screw and nut. Make sure you mount the fan low on the radiator for hood hinge clearance. Please note this fan will require a relay setup to power the fan. The Classic harness was not designed to handle the load. I have a wiring diagram for the relay if you need it. I've been mounting them this way for years with no problems. DV is right about the straps, they will work but over time they can cut into the core.
Don
