Thread: Dipstick raises
Old 05-04-2015, 02:05 PM
ACademic ACademic is offline
I guess an option is to install a vacuum pump system.
Or maybe install a small worm clamp on the tube and extend a small, low tension spring (read: easily removable) from the clamp to the dip stick handle?
Kevin, if you are not experiencing either excessive oil consumption (blow by past tired piston rings or valve seals) or strong fuel odors in the crankcase oil, I doubt you have a rings issue and I'd just perform a simple fix and drive it.
