I just replaced mine on my BDR. Not sure you will have the same issues as I did, but here it goes. The new glass did not fit my frame. Had to get new frame and glass. The new frame was about 1 ½ wider. The body had to be cut out a little on both sides for the support post. I was able to reuse the cover plates where the post go through the body. Spacers had to be added to the mounting points (very important). Sun visors mount differently and at a wider spacing. (may be just BDR). Check your angle of your old windshield so you can math it or make adjustment as you like. The new post are not pre drilled.
Best of luck
