Old 04-24-2002, 09:56 AM
ToyCollector ToyCollector is offline
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
Default Check your throttle linkages!
Hi y'all,
Wanted to share a somewhat funny story with you, and one tip that I know all old time hot rodders can tell you to continually check and was fresh in my head when I was 18.
As some of you know, I have a car with a very healthy 427+ built by Southern Automotive. I had bent a push rod late last season and it ran crappy last fall/winter. It was emitting more belches and backfires than the beer drinkers at a NASCAR event--I resmeble that remark by the way. Bill diagnosed the pushrod problem, gave it tune up, and car idled and ran fine. However, I had continually noticed that either I was getting used to 500 HP and it just didn't seem as thrilling, or car was losing power VERY gradually. I had repeatedly told people like excelguru and Jeff Neeely that the car doesn't seem all that quick at times. Since it ran fine and had no unusual symptoms, I thought I was becoming the next NHRA's John Force in the making and that my perception was all in my head."
THEN, this weekend, within a 10 mile drive, I am putting the pedal to floor to make it go and it DEFINITELY wasn't quick in Cobra terms. Luckily I was close to my house when I realized something was way wrong. For you older SPF owners, there are two allen bolts that link your GO Pedal with a shaft that connects to carburetor linkage rods. Mine was slipping and then grabbing with only about an inch of pedal to floor clearance in it's worst state, although a wrench showed those allen set screws as tight. A call to Olthoff came back with the suggestion of upgrading to bigger bolts with same thread, using set nuts, and grinding a sharp point on tip which I did. Oh boy did I enjoy the "test drive"!! :3DSMILE
My wife said she hadn't seen me smile like that since...well we won't go there It was like I found 150 or more horsepower. For anyone who has gotten a ride since I have owned the car--I apologize that you weren't getting the full effect--refunds are in the mail . Get someone to step on that pedal and make sure those butterflys are "straight up and erect".
