Originally Posted by Xack
You can purchase louvers to fit in the area to keep dirt from being thrown up onto your headers and route the air to the vent.
This example is for a West Coast Cobra. It did not have any fender wells at all. As you can imagine, dirt would go everywhere. You should be able to add the louver from the back side on three holes drilled to match your vent hole pattern.
Interesting idea for sure. So this is two sets of louvers you have, 1 set facing up, 1 set facing down?
I have not installed the screen yet so I have no holes to worry about, just the heat shield locating holes.
Do you have dimensions for the louvers and maybe a link. They look quite a bit smaller than the screen. Perhaps I could use this instead of the screen. Paint it black, it will blend right in!
