Thread: Dipstick raises
  #22 (permalink)
Old 05-10-2015, 01:04 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by CHANMADD View Post
The pcv system is a system on its own. The breather is the intake filter...pcv is the suction pump . The pcv must be large enough to allow sufficient airflow through the engine , without allowing the oil to bypass. If it persists you probably need rings....
I wonder if what I described as the pcv system was actually read by anyone!
Correct up to a point.
Blowby at part throttle may only be 20-50% of the blowby at wide open throttle.
So if the "breather" being a filter, or a tube going the airfilter isn't large enough to handle the volume of blowby, then something usually gives.
Either the dipstick gets pushed out, oil leaks develop, or both.
Gary
