Originally Posted by Ace23
Compression test results are 1-150lb, 2-160lb, 3-160lb, 4-160lb, 5-155lb, 6-160lb, 7-162lb, 8-160lb cranking with a brand new optima red top. I spoke to the engine shop and they said it should be 175-180lb per cylinder and that the last tuner back in 09 must have simply tuned the car too rich and this is a result of washing the rings.
you need to contact keith craft, and ask him, as he built the engine, knows the cam, and what the static compression numbers should be.
years ago, at one of the cobra builders/ engine shops, I had some work done on my FE 427 (429 displacement), and got 455 rwhp. That same cobra/engine builder had installed numerous roush 427r's, and I think the best rwhp he ever got from any of the crate roush 427r's, was around 420, even after dyno tuning with the best side pipes. So, it depends a lot upon the dyno.
