Old 05-13-2015, 05:25 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Mike,
Shock specs depend on which Jag rear you use, as the lengths of the lower arms (wishbones) are different.
As far as I know there are three stock Jag lower arm lengths, from shortest to longest: XKE, 3.8S (and related), XJ6/XJS. Track width varies accordingly.
The shocks you need will depend on which arms you use, or if you are changing the lengths of yours (i.e. shortening the XJ6 arms).
I use the middle length, for the 3.8S sedan length wishbones, and the four shocks are from Aldan: PAS657.
I agree there is a "correct" length for each, as mine were too short to begin with and made for some interesting pucker moments on the track; as the car rolled a bit during a turn, the inside wheel would lift - picked up by the shock which was fully extended - and cause the car to skip sideways. Lengthening the rear shocks helped immensely!
Studying the ERA site (their 427 Jag rear specs specifically) leads you to this shock they use: Rear Jaguar damper, adjustable
Recognize your shock mounts may be different either from theirs or my Aldans...
Happy hunting,
Tom
