Old 05-15-2015, 11:31 AM
jhv48 jhv48 is offline
First, crawl under the car and see if there is any fluid on the slave cylinder. If everything is dry, then fill the reservoir and bleed the system.
If the bleeder is on the top of the slave, all you need to do is open the bleeder valve and pour brake fluid into the reservoir. Gravity will bleed it for you. Just don't let the reservoir go empty while it bleeds itself.
Jim
