  #21 (permalink)
Old 05-16-2015, 01:45 AM
eschaider's Avatar
I didn't comment on this earlier but should have. If your flywheel is cast iron and you have an OEM bellhousing you might want to minimally invest in a steel flywheel — you only have one set of feet.
Even with a steel flywheel a clutch cover can become a problem which argues for a Lakewood, Quicktime or other bellhousing designed to protect your legs and feet from unexpected clutch and flywheel failures.
While not not required to operate your vehicle, both are a good investment to protect yourself, just in case.
Ed
