Old 05-18-2015, 04:01 AM
Default Look at Canton
Horseracejudge Nick take a look at Canton oil pans if not looking for period correct. You didn't say if your motor is running a windage tray? Also look about increasing the amount of oil too. If you are running 5 quarts would go to 7 quarts. Reason being, when coming off highways on long off ramps the motor doesn't have any oil starvation issues of going dry or airating. The higher the side "G" the harder and longer it takes for the oil to return to the pan. Good luck Rick. Ps watch your ground clearance, Canton pans are wide but stay above the bellhousing. You would need a new pickup but on most applications the pickup has a larger tube for more supply to the oil pump. Good thing.
