Great update and über cool fabrication work as usual.
That belt alignment tool is just awesome.
For what's its worth, my old car has a squeaking belt and I knew it was an allingnment issue. I remover the belt and used builders string line Around the belt path and sighted this by eye. The idler pulley was out 1.5mm. So I changed the spacer behind the pulley and it all lined up, squeak gone.
