Old 04-25-2002, 09:39 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
dcapo, For the upper I use 2 hoses both Napa part# 7096. You will need to trim them a little to fit the in-line filler. For the lower I buy a 1 3/4" hose with a 90 degree bend in it. Sorry I don't have a part number. I make a tube in a kind of an S shape to go between the rad and water pump and use a small straight piece of the 1 3/4" hose from the tube to the rad. The other end I use the 90 degree bend to the water pump and the tube. The easiest way to make the tube is use a piece of wire and fashion the bends from one side of the car to the other, take the bent wire to an exhaust shop and have them bend a piece of 1 1/2" exhaust pipe to match the wire, have them flare the ends a little so the hoses won't slide off after clamping. The other thing I do for the lower if you don't want to try the tune is buy a piece of cool flex hose the proper length. I hope this isn't to confusing.
Don
