Luce,
The problem appears to be heat related, so it is not likely the filter.
A failing pump could be the problem, but it may also be that an old, well worn pump is running hotter than in years past. When the combination of hot environment and hot pump combine, vapor lock in the pump can occur.
Tommy
Previously owned EM Cobra
