  #21 (permalink)
Old 06-11-2015, 09:46 AM
C5GTO's Avatar
C5GTO C5GTO is offline
Default CR soft top bow pics
Originally Posted by Wisconsin_Snake View Post
Would you be willing to take a couple pictures of the bows for me.. I need to make a set for my cobra when I get it completed. Any references via pics and measurements would be valuable.
Thanks
There are 4 bow pieces with slip joints. The bows are split so they fit in the trunk. In fact, the soft top and side curtains all fit in the trunk so you can take them with you if the weather is iffy. Thankfully, in California the weather is usually predictably sunny
When assembled, the bows mount into a fitting just behind the doors. The back bow goes just behind the roll bar.
It's a fairly simple setup but surprisingly strong and stable. Please let me know if you're interested in obtaining the whole soft top setup. I'd even be willing to throw in the old tonneau cover (worn out but still good for a pattern) as it has the same spacing for Lift-a-Dot studs as the soft top
Thanks,
Joel Heinke (early 90's CRL Cobra)
