Originally Posted by Dangerous Doug
I have the outboard brakes setup. The flex lines to the calipers are BSS, as is a flex line from the subframe going to the steel lines on the frame. Came from ERA that way as I recall.
You've found a kit for flex lines in the front, yes? On the rear, can you find an adapter that will allow you to mate 7/16 and 3/8?
So you having the outboard brake set-up is a whole different animal as I thought!
I wanted a replacement SSB line for the rear to fit just like it was originally from ERA. I don't know enough about lines as I said earlier.
check this thread out:
Rear Brake Flex Line
This guy hooked me up with the exact line that he will build.
No I did not find the lines for the front yet, I wont be doing the front brakes until winter. I want to upgrade to the SSBC calipers, SSB lines, and new rotors.
As for the rear rubber line / SSB replacement.Going for a kit and trying to get the dimensions and fitting info for the one line I needed was almost impossible. The lines are not identified individually. Russell's own techs could not even do it
