Old 06-14-2015, 10:57 AM
Mark Brye's Avatar
Mark Brye Mark Brye is offline
Cobra Make, Engine: BDR354/FMS392
My door had a terrible squeak. I found that it was the foam door seal rubbing against the door. I took a rag with some s303 on it and wiped the seals and six years later the super loud squeaking is gone. I also found a coin from South Africa behind door panel that rattled. Fixed a squeak in rear suspension that was the rear spring rubbing in lower spring bucket. Just rotated spring a little and all is good. Hood prop rod rattled in its mount. I used a dab of liquid rubber there. Been annoying sounds free for last six years but did take a couple years to find them all.
