You have received a lot of excellent advice. An ERA is an excellent choice. Take a look at areas that you can cut back on, being that you are looking at a street able car. The motor is one area; a modestly built 428 will give you all the power that you will ever red (tons of low end torque), will have the FE look to it and could shave off some significant dollars. If down the line you feel the need for more power (which is doubtful given the weight of these cars), you can always pull the motor and have it upgraded. A lot easier to do that, than to try to upgrade other options.
Take the family for a vacation, or talk to Peter and make a visit to CT yourself. Good luck, you will not be disappointed.
