Old 06-16-2015, 08:47 AM
Young1 Young1 is offline
Cobra Make, Engine: Unique 427 S/C, FE 440, top-loader, 3.31
Default FE Leaking oil at distributor
OEM block. Mallory Diz. Edel manifold. Started leaking at hole badly 2 k miles ago. Put in a new felpro seal. Slid in fine all is aligned in hole. After 3 heat cycles leaking again. Motor has 14 K on it. I have a Pcv valve in manifold. A k and n breather on valve cover. I have increased blow by being a bit messy around breather. What can I do with this distributor leak? Messy motor in FL
