Update, well kind of.. I sent the booster to a booster rebuild place on the west coast. They are not able to rebuild it because they cannot identify what booster it is other than the size and that it is made by Ate. Still waiting to here back from BDR to see if they have found one.
In the time being have been looking at new boosters. The boosters from speedway have a single diaphram 8" about the same size as my bad one. Or I could get a 7" dual diaphram but it is a couple inches longer and would put it closer to headers. To do either, I will need to drill new holes in fire wall and also get a new master cylinder. Also I will have to bend new brake lines and fittings to match.
I have the wildwood bbk kit on the car. The instructions for the brakes say that a 7/8, 1" or 1 1/8 inch tandem booster is used for this brake kit. What size should I get? Not sure would size the existing master cylinder is. It seemed to work fine.
Jay, what size booster would you get and do you have an idea on what size master cylinder to get?
Thanks
