Originally Posted by Modena
Peter, I see your water outlet is not directly straight-out and I'm sure you intended that, but you can buy a straight water neck if you want one.
Ben, I think it's the water inlet on an LS1?
Originally Posted by Tenrocca
Hi Pete, check your coolant is recommended for ls engines. my understanding was you had to use the orange stuff.
cheers
Thanks Andrew. I looked at the Techaloy site and they suggest three green (I'm using one, 90 Plus) and three red coolants for a VZ SS LS1 motor. Very difficult to differentiate.
