I don't have that setup from them but I do have the eight-stack. I love it and I think the cross-draft is gorgeous, I liked the near classic look. I'm sure you would be happy if setup correctly.
When you consider costs: Don't forget you will have to replace the fuel pump, add a high-pressure fuel line, and provide for a return (use the old line). You may also want to consider a different cam to ensure proper tuning, or you may get less than expected performance. I will let Keith Craft or one of the other engine builders comment on the specifics.
