Originally Posted by Large Arbor
I had to enlarge the hole, but that was not a big deal. I simply removed the old puller and locking mechanism, was careful with the leather and drilled the whole through the wood and put the lock on. It works great! Let me know if you need more pics.
Phil
More pics would be great Phil. Maybe with the back side and where it latches. Does the lock actually hold the door closed now or can you retain the dohicky that keeps it closed? How do you open it without the pull?
My pull is located about 1 1/4" from the hard edge. I measured this on the backside of the door. Is this the standard location for this knob?
Thanks
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
