Ls3 crank sensor p0315 code
Hi All,
When I first wired up my car (ls3 with factory ecu vats removed) it started first go. It ran a bit rough, but I had no cooling system connected so couldn't warm it up. Motor was a crate motor.
After not running it for 12 months, i tried to start and it wouldn't. It has no spark.
I finally hooked up a scanner today and got p0315 code crankshaft position system variation not learned. From my research this is not a code that would stop it running and the engine needs to run to run the learning procedure. Given its a crate motor with second hand ecu, it's probably no suprise. Anyone know much about this code and if it could cause a no start situation?
I also had a code for clutch position connected to ground but didn't write down the code. My harness has no clutch sensor.
