06-21-2015, 12:10 PM
AR
If you decide to try a little wet sanding, soak the paper for about 15 minutes first in water with a couple drops of liquid soap. Unsoaked sand paper will leave deeper scratches. I've had problems with Meguires 3000 sandpaper scratching unless I soak the heck out of it. Less problems with 3M 2500 paper. First I would try a foam polishing bonnet on a buffer or electric drill and some polishing compound.
