Old 06-22-2015, 03:03 PM
Kit Coyle Kit Coyle is offline
Cobra Make, Engine: ERA FIA #2064 BOSS 302 CSX2047 sold
Default 302 Engine Problem
I have a sudden engine problem and hope someone here can point to a
solution. The engine is a BOSS 302 with a Holley 650 double-pumper, MSD
6AL box, MSD Pro-billet 8479 Dist. and an MSD 8222 hi-vib. coil.
Five minutes into a ride the engine suddenly began to run so roughly that
I pulled off the road. The engine quit and refused to restart. After sitting 30
minutes I got it to start and run well enough to turn around and coast in
neutral downhill to home. Suspecting I might have damaged plug wires from
a boot change I checked the resistance and found them in spec. The coil also
checked good @ .6 ohms primary and 4.55k ohms secondary. The dist. cap
and rotor checked good as well. The engine easily restarted but still ran poorly.
At 3000rpm the right side exhaust expelled white smoke. At shut down I
noted gas had dampened the phenolic block on the right side of the carb and
dripped down wetting the intake manifold. The next day the engine again
started easily and ran very poorly. No white smoke this time and no gas
leak until after shutdown. Fuel pressure is 6psi. Do you think my carb is
flooding? Could my coil be bad even with a good static resistance check?
Has the intake manifold gasket failed? Thank you very much!
