![Old](/forums/images/statusicon/post_old.gif)
06-24-2015, 02:50 PM
![Jac Mac's Avatar](http://www.clubcobra.com/forums/image.php?u=23898&dateline=1266522763) |
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
I prefer using top gear or in the Tremec case whichever ratio is 1 to 1, less chance of trans/driveline damage.
Jack car up under diff with wheels clear of ground. Start and run at ~30mph with foot on clutch pedal, drop car, job done usually. Make sure you have room to steer & brake if it doesn't work first time.
I used to work in a shop that had many long term projects where this was a regular occurrence, Boss always thought I was real quick at clutch replacements- not sure if he ever found out what I was really doing!![Smilie](images/smilies/smile.gif)
Jac Mac
