Originally Posted by Kit Coyle
The problem was debris in the Holley float needle/seat housing allowing
the float bowls to overfill. I removed the assemblies, cleaned and reinstalled
them and reset the floats. It runs perfectly now. That you for the help.
I had the same problem with a QF. Beside cleaning the carb, the fuel filter near the electric fuel pump by the tank was almost completely clogged with debris. I replaced it with a much larger filter. The old one was a Fram see thru plastic filter. A real cheapie. Just a thought.
