Old 06-29-2015, 03:06 PM
tortuga tortuga is offline
Default Oil
Originally Posted by JBCOBRA View Post
+1 Sideways.
It seems to be a pretty common problem. I have changed mine too. So Tortuga I hope you get lucky!! What does the oil look like???
I am using a Victor Jr intake. Motor sucked in the gasket from the top side of the engine on deceleration from high rpms. So when I replaced the gaskets I put a bead of the Right Stuff on the top side of the gaskets after I torqued the intake.
Knock on wood, no recurring problem
Oil looked fine, water looked fine, however on cranking over with the intake removed it puffed out the water jacket aft of No. 8: figured headgasket...Now after buttoning the whole mess up i think i am seeing coolant; Either i F'd up the headgasket install in exactly the same place as the problem or i have a cracked head...
Feels like i bought a problem at this point; 12 year old car with 5k miles...
Superformance 1764
Built 427W
Aiken SC USA
