Old 06-30-2015, 02:30 PM
Barry_R Barry_R is offline
For whatever its worth I don't think the extra ten pounds from 90 to 100 is going to matter a whole lot unless you can verify that that value is what was originally used to hone the block. When we check torque wrenches on a strain gauge I see that much variation from tool to tool.
And some of it will depend on the lube used as well. The crush load applied at a given torque value will be increased with each tightening sequence for a few efforts as well as the threads burnish in to each other and friction is reduced.
I would not lose much sleep over it.
I have had customers request that we put a ball bearing in the bottom of each stud hole so that the studs do not bottom out and "cock" on the threads - an interesting idea. I have seen other studs (A1 used in Shelby blocks) that had an extended nose on them to accomplish the same task.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
