  #115 (permalink)
Old 07-02-2015, 06:32 AM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Since I used a tremec without a shorter input shaft and did not use a toploader bellhousing, the transmission mount was off about 1/2". I had a friend cut out some new mount brackets and then had my welder TIG them in place on the frame.
I'll spray the entire crossmember with black epoxy then topcoat with a paint that matches the powder-coating.
Now that the transmission issue is taken care of, all I need to do is register the car and install the interior.
[IMG][/IMG]
[IMG][/IMG]
